Results 1 to 10 of 13
Thread: E38 and E67 - GM Original Reprogramming
    Aug 2006
    Default E38 and E67 - GM Original Reprogramming
    Hoping this is not inappropriate, but I'm posting this knowing how difficult it is to get a local GM service shop to recalibrate an ECM/TCM apart from the vehicle. Had I not already gone through the inconvenience and difficulties of convincing the local GM service department to do a few Tech2 ECM recalibrations using a provided benchtop programming harness...
    With the recent release of the EFI Connection 58x system for early SBC and late 7.4L BBC engines, we had to get set up for GM TIS-SPS programming to initialize new Gen IV ECMs/TCMs and be able to reprogram used Gen IV ECMs/TCMs with new base GM tunes.
    In other words, turn an Impala E38 into a Corvette E38...where the issue is that a full flash aside from a GM TIS-SPS reprogram will not overwrite all calibration segments.
    If you are in need of this service, please contact [email protected] or visit http://www.eficonnection.com and click on "GM Calibration Services" under "ECU Programming" in the left side navigation.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    Jul 2003
    Hm.. that I didn't know. So you can turn a 2008 E38 into a 2010 E38?
    If he wants some doorstops shaped like an E38 then yes.
    Aug 2006
    Like suggested above, it's something to be careful of.
    The Ram Jet 454 we have running on the test stand with 58x equipment is using an E38 pulled from a 2008 Impala. It was reflashed with a 2008 Corvette calibration using the GM TIS-SPS service. After the GM calibration we were good to go with EFILive tuning.
    TIS - Technical Information System
    SPS - Service Programming System
    There is also a 2007 Impala E38 in the shop that has been reprogrammed with a 2007 Corvette calibration.
    The salvage yards are still proud of these ECUs (prices are high), so I won't be the one who tries a 2008 calibration in a 2010 ECM (and so on).
    Quote Originally Posted by S10Wildside View Post
    Others have and it will end in tears.
    There is 4 different E38 part numbers now, two that seem to cover all 2006-2008, then one for 2009 and finally the 2010 ECM.
    12597121,12612384 = 2006 - 2008
    12625455 = 2009
    12633238 = 2010
    There is a few threads on here that have discussed this in depth.
    Redline Motorsports
    Guest
    Ross,
    Are the 2006 to 2008 PCM's interchangeable??
    Howard
    Yes and no Howard.
    The 2006/2007 should be fine, worst that will happen with a 2008 is the VIN will get corrupted and the Crank Relearn will need to be done.
    Thinking about it, 12597121 probably covers 2006-2007, 12612384 is for 2008.
    Aug 2005
    Yes and no Howard.
    I've never been able to flash an 08 calibration into a 121 ECM. Haven't tried working it backwards.
    Tried flashing a '10 truck cal into a junk 455 ECM (broken retaining tab) and it took the calibration fine, EFILive couldn't retrieve the calibration though.
    Dec 2007
    Quote Originally Posted by dc_justin View Post
    If you put a real '10 OS into a 5455 E38 then you probably have a brick now.
    12633238 is the '10 as Ross listed above. GM parts info lists it as "no start" if cal is not right.
    Aug 2005
    Quote Originally Posted by gmh308 View Post
    It was a useless E38 to me as it was and had to test a theory. GM listed both the 5455 and the 3238 for that truck for some reason, depending on software version.
  1. Scanning on original ecm?
    By 1BadAction in forum General
    Last Post: April 1st, 2009, 07:52 PM
  2. Original Bin File
    By markemac in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2008, 12:57 PM
  3. Looking for Paul's original .PSD dash
    By mistermike in forum Tips and tricks
    Last Post: November 25th, 2006, 04:20 AM
