Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Go with an autometer wideband?
    Oct 2006
    Default Go with an autometer wideband?
    I have a LS3 Camaro now to play with and need a WB.I ordered an autometer cobalt LED WB because I like the looks and it will match the other guages I got. It seems that not many people are running an autometer WB? Why is that? I can return it and get something else if need be. It shouldn't be too big a pain to get EFI live to log off it right? And it should be accurate? Nows the time to change if need be since I haven't put it in the car yet. Thanks in advance
    Philip
    V2 from Tippin
    2010 Camaro LS3
    Nov 2006
    IMO
    Steer clear of anything that can't free air calibrate or doesn't give the Lambda output range.
    LC-1 WBO2
    swingtan
    Guest
    I went with the Techedge 2J1 WB controller and an LA1 Circular Display. While the pair will probably set you back a little more than the Autometer, it does have a free air calibration as well as a serial port to connect to the V2. If you don't go with serial, it has a ground referenced analogue output to eliminate ground offsets.
    You may be able to ask them to do one with blue digits....
    Simon.
    Oct 2006
    auto meter # 6178 http://www.autometer.com/cat_gaugede...gid=3606&sid=4
    Notes:
    Includes 8 ft. tubing or wiring harness.
    LED digital display.
    0-4v data output feed for ECU, data acquisition unit, or Laptop tuning
    Auto-Dimming gauge brightness feature
    Includes custom tuned .1 AFR Resolution Bosch LSU4.2 Sensor
    Display data in Lambda or numerical A/F ratio
    User programmable range
    Peak recall/memory
    10:1 to 20:1 AFR Range for Gasoline Applications
    Adjustable for Alternate Fuel Types (Ethanol, Methanol, Propane, CNG)
    6:1 to 18:1 AFR Range for Alternate Fuel Types
    User Programmable Warning Function
    This product has no provision for dial illumination/backlighting.
    Guessing free air calibration you just have it calibrate itself sitting out side the car?
    Philip
    V2 from Tippin
    2010 Camaro LS3
    Nov 2006
    LC-1 WBO2
    Oct 2006
    That poll is why I asked the question. Figured there had to be a reason no body was running autometer WB's lol
    Philip
    V2 from Tippin
    2010 Camaro LS3
    Nov 2006
    That poll is less than a week old, it would be nice to get more members to vote.
    LC-1 WBO2
    swingtan
    Guest
    we need one of the mods to force all users to vote..... :p
    How do I do that...?
    swingtan
    Guest
    I know you can force users view and acknowledge certain posts, like the "terms and conditions" page. I don't know if this extends to general threads though. It's probably more of an "admin" task in the end to set it up.
    Simon.
  1. autometer wideband
    By truethinker in forum External A/D inputs
    Last Post: April 6th, 2019, 10:11 AM
  2. need help with wideband autometer
    By pdasterly in forum Gen III V8 Specific
    Last Post: May 31st, 2009, 03:47 PM
  3. how acurate is the d-pic from autometer
    By tokymon in forum Vortec V6/V8 Specific
    Last Post: June 4th, 2008, 10:27 AM
  4. Will autometer egt work v1 hardware
    By red12secz28 in forum Diesel
    Last Post: August 21st, 2007, 04:37 AM
  5. Autometer AFR Gauge & EFILive
    Last Post: April 18th, 2007, 03:55 AM
