Results 1 to 10 of 11
Thread: 2006 auto gto cant do a burnout
    Sep 2007
    Default 2006 auto gto cant do a burnout
    trac control off, maf enabled still- what am I missing???
    Jul 2003
    more Power?
    Aug 2008
    more Power?
    Haha.....
    FLASHSCAN V2 & AUTOCAL
    Aug 2008
    Post up your current tune rubbersidedown
    And a log file.
    Jul 2008
    Maybe your tires are just too good (too stickie..)....
    You can also adjust your air pressure if burnouts are your thing. Just be careful not to blow out your tire or break an axle.
    Jul 2003
    I mean come on... I don't think it's a tune problem... why do we try to solve everything with a tune?
    If traction control is off a burnout shouldn't be a problem...
    We just want to look at his files to see what he should be able to do.
    It is actually a problem with the EBCM, but it should be fixable in the tune, or with a zip tie.
    http://www.ls1gto.com/forums/showthr...omatic+burnout
    http://www.ls1gto.com/forums/showthread.php?t=256390
    These should help, you can tune it out, but it was a problem on some 2006 automatic cars.
    My 2006 manual has no problem with burnouts.
    Ryan
    Max out BO704 and check BO701
    That took the tires clean off my old Volvo with 12603159 operating system.
    Good Luck....Nothing worse than a GTO that won't burn the tires!
  1. Tuning for 2006 Pontiac G6 3.5L Auto
    By Kevin@SpeedMafia in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2010, 06:14 PM
  2. Ute Burnout
    By Tre-Cool in forum Lounge
    Last Post: January 21st, 2010, 02:25 PM
  3. trans feels like slipping after doing a burnout
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 12th, 2009, 03:09 PM
  4. Need a 2006 Corvette 6speed auto file.
    By John02SS in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2009, 02:16 AM
  5. Burnout Videos from my GMC Typhoon
    By Tydriver in forum Lounge
    Last Post: December 29th, 2005, 08:19 PM
