I am looking for a tune for a 2010 camaro l99. With prochager nothing else. Will pay for tune. Thanks
Hi SOS, welcome to t he forum...
Where are you located...?
I am in alberta canada. If you have tune i know someone that can put tune in. Just need tune. Thanks
Why don't you bring your to a professional facility that can properly calibrate your set up.....
8 hours to go to dyno shop. I live in the north part of alberta. Car would have to be towed.if you have a tune i can install it. Then take to dyno shop. Thing not so easy to do in the great white north.
Hmmm, you're pretty remote (the internet makes the world look small)...
So you need a starter tune that will get you driving to a dyno shop...
So that's all the mods, the ProCharger P-1SC-1, how many psi...?
People are reluctant to just give you a tune without at least seeing your calibration file and some logs because they don't want to be responsible for any damage...
At the very least, whether you install a tune that someone gives you, or if you make an educated guess on your tables, you will still need to measure/adjust with a wideband before you drive 8 hours to the dyno shop.
Where in Alberta are you. Did you get the car tuned? Send me a PM I may be able to help.
Im tuning the car remotely using EFILive.
Oztrack
EFILive Tuning Consultant
Worldwide Remote Tuning Service
2006 NSW Super Street Drag Racing Champion
www.oztrack.com.au
Car is tuned now. Steve @ oztracktuning got it fixed. Thanks steve
