Holy crapola....you will never believe this. I looked at the log again and the commanded AF was 11.6 and map was at 13.9.....I went and checked the map and found it had come unplugged I guess when I swapped the injectors. I had to go back and play with the VE alot but I got it running correctly now. I will make some logs tonight and report back.
