How would this work (dont have a wideband currently but will have to get one)
Dissable the MAF
Run off the VE table but increased 10% everywhere (called CLSD right??) -- (use LTFT to get BEN or WB later)
Correct VE table and check (drive but not entering PE mode, where is safe not to ask for PE enrichment, its hard to hit high rpm cells with high MAP without going into it)
How can you adjust timming here??
After VE set:
Set PE to 12-13 ish (after I test the best fastest burn point where i start to get knock on stock timming table - discussed in other post)
Set timing so there is no knock with a PE AFR range between 12-13
Do i really need a good VE to sort out PE mode, doesn't the MAF become exclusively used above 4000 rpm thus NOT using PE at all?
