Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: order question
    Nov 2006
    Which AEM do you have?
    for serial connection:
    30-2310 = gray wire
    30-4100 = blue wire
    LC-1 WBO2
    May 2010
    i have 30-4100 = blue wire
    May 2010
    today i installed the AEM UEGO wide band the WOT A/F seems good =>12.8
    but the problem was the idle ratio its 11.8-12.1 which is too rich
    the cruise ratio is rich also 13-13.2
    now what tables should i consider to correct this problem
    Jul 2008
    wesam:
    Welcome to the forum.
    Since I have been a member a little short of two years, I will try to give you a 'road map' to tuning, and all the great Tutorials and Tuning Notes.
    Since you stated you are running SD, I would really take a look at the following: http://download.efilive.com/Tutorials/PDF/AutoVE Tuning Tutorial.pdf.
    Follow it to the letter. If you get in trouble, post your tune and log. From my experience thats when you really get the best responses from knowledgeable members. Read every thread you can, and utilize the great search features. Here is a brief 'cliff note' on differing tuning methods..http://forum.efilive.com/showpost.ph...0&postcount=21.
    Another great place to start..http://forum.efilive.com/showthread.php?t=7867.
    Congrats on your wideband. I would really read through those Tutorials. Not only will they help you, but then if you run into trouble others will know that you have the basic research down.
    Good luck..
    May 2010
    well i had read all those posts
    good information
    but still not enough for me is there any e book i can read which will illustrate the purpose of each table
    also i still wait for the flash scan i don't know why i did not receive any tracking number !!
    Jul 2008
    Links:
    good information
    but still not enough for me is there any e book i can read which will illustrate the purpose of each table http://www.calibratedsuccess.com/
    http://www.cartechbooks.com/cartech/...files/8046.pdf
    also i still wait for the flash scan i don't know why i did not receive any tracking numberhttp://www.efilive.com/index.php?opt...=95&Itemid=114 !!
    May 2010
    why the hell there is no contacting number in the EFI Live ?
    i want the tracking number and sent them a help request 3 days before and still no answer!
    is this normal ?
    Oct 2004
    Send your order # to [email protected]. I'll see if I can find anything out for you.
    Andrew
    EFILive Crew
  9. #19
    May 2010
    order number is sent
    looking forward to hear from you
  10. #20
    Oct 2004
    I'll check tomorrow (Saturday) and see what I can find out for you.
    Andrew
    EFILive Crew
  1. How are mail order tunes done?
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2008, 10:46 AM
  2. how do i cancel an order
    By goodwrenc92 in forum General
    Last Post: September 4th, 2006, 04:06 PM
  3. mail order tunes
    By redls1bird in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2006, 02:11 PM
  4. Order status
    Last Post: February 12th, 2005, 01:36 PM
