I was wandering if someone could give me the TCC settings for my Allison in Pat A or should I just use the ones from Pat B?
Needed are Apply & Release for all speeds.
Someone else was into my TCM before me and changed them a BUNCH.![]()
I have all the rest saved but never had Pat A that was correct.
Stock will be fine, I can play from there.
Thanks, YB Normal
The tranny is a LB7/LLY 2000 in a 99 Dodge Cummins. The TCM is the same as the 1000.
