Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: order question
  1. #41
    i don't think it will work because pin 3 is for calibration ( for sending data not for receiving data ) in Innovate WB
    and AEM don't have calibration feature
    On DCE devices: Tx receives data, Rx transmits data.
    FlashScan is a DCE device.
    See here: showpost.php?p=109717&postcount=19
  2. #42
    May 2010
    Its workiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiing
    thanks joecar i'm glad for you
    now the tune will be much easier
  3. #43
    May 2010
    now just one last thing how could i go backward while play back the saved log ?
  4. #44
    Nov 2006
    I don't think you can go back while playing.
    You can scroll manually in a chart tho.
    LC-1 WBO2
  5. #45
    May 2010
    so if i want to check some thing back i should repeat a 7000 frame log again ?
  6. #46
    If you display the log in chart form (see the Dash tab B), you can view the whole log, zoom in to a portion and scroll back/forth.
    You can add/change pids on the chart.
  7. #47
    Nov 2006
    You only need to replot or filter it once then move the scroll bar at the bottom back & forth.
    LC-1 WBO2
  8. #48
    What mr.prick said works for any of these displays:
    - Data tab,
    - Dashboard A (gauges),
    - Dashboard B (charts),
    - Maps.
  1. How are mail order tunes done?
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2008, 10:46 AM
  2. how do i cancel an order
    By goodwrenc92 in forum General
    Last Post: September 4th, 2006, 04:06 PM
  3. mail order tunes
    By redls1bird in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2006, 02:11 PM
  4. Order status
    Last Post: February 12th, 2005, 01:36 PM
