Results 31 to 39 of 39
Thread: Traction Control Tuning
  1. #31
    May 2010
    The basic settings are.....
    • All torque reduction control setting are set to off, except for B0517
    • B0517: TCS Torque Reduction By Thrttle Option - is set to Yes.
    • B2501: TCS Maximum Engine Torque - is set to a value over the expected peak torque. In mine it's 700 Nm
    • B2502: TCS Minimum Engine Torque - is set to the least amount of torque wanted. Mine is set to 80 Nm
    • B2503: Delivered Torque Upper Duty Cycle - set hi, 90% for me.
    • B2504: Delivered Torque Lower Duty Cycle - set medium, 35% for me. I think this helps set the control of the torque delivery when TCS is active.
    • B2514: TCS Throttle Limiter By Gear - All maxed out.
    • B2517: TCS Throttle Limiter By Input Speed -This is where it all happens. Set torque limits for each gear and RPM to suit the traction expected. The real work is done in 1st and 2nd gear. Here are my settings....
      1st Gear
      • 147.625000
      • 157.500000
      • 168.500000
      • 183.250000
      • 220.000000
      • 273.500000
      • 325.625000
      • 399.375000
      • 700.000000
      2nd Gear
      • 162.750000
      • 173.875000
      • 189.875000
      • 215.250000
      • 258.125000
      • 314.875000
      • 388.375000
      • 480.500000
      • 700.000000
      3rd and 4th are just higher settings again.
    • B2522:Torque Reduction Max - I have this set to 100 Nm
    Now, with these settings and TCS turned on ( I.E. I haven't turned it off ) taking off hard on good dry bitumen has virtually no "detectable" wheel spin when sitting in the drivers seat. You can also feel the torque management release as you go through 3000 RPM. If you check the log data though, you can see around 5 to 10 kmh of wheel spin. So there is plenty of power getting to the rear wheels, just not enough to really light up the tires.
    Simon.
    I did not find those parameters in my .tun file is my operating system different ? i have a LS1 Lumina SS coupe (GTO)
  2. #32
    swingtan
    Guest
    That would be because those settings are for the E38 controller, not the LS1.
    Simon.
  3. #33
    Jul 2005
    I don't suppose some clever bod has produced a set of numbers for B66** numbers (LS1) cotrollers as a jumping off point and would be prepared to share. It would be greatly appreciated.
    Just got off the showroom floor, now lets fix it.
  4. #34
    Jul 2003
    Well..
    I have my road runner installed. I will be tuning this a bit in my car these coming days. I am going to strap my car down on the dyno and test and Tune b1902 FIRST. After that it's more or less b6612 to have a complete control of what torque output you get. I believe that once you set both of those tables on the LS1, the rest should come quite easily.
  5. #35
    Jul 2003
    Retarding 9 degrees on a cammed car are going to yield a torque loss far greater than 3% as on the STOCK calibration.
  6. #36
    May 2010
    Pulling this from a dead
    Did you tried this on dyno ?
    Do you think its linear relationship between timing and torque so 16 degrees of timing will make 6% torque loss ?
    EFILive Tuner
  7. #37
    Jul 2005
    My VZ would practically stop when the TC cut in, so I decided any change was probably better.
    As a first step I simply reduced B6603 TCS Spark Retard by 50% and the result was great. No wheel spin, but the torque drop
    when TC cut in was way less. It needs more work but for one change the results are amazing.
    Cheers Steve
  8. #38
    Jul 2003
    The problem is that when you really want it which is on the WET... torque needs to be cut even more or you will get wheelspin and dangerous situations.
  9. #39
    Lifetime Member macca_779's Avatar
    Jan 2007
    Quote Originally Posted by vzsv8 View Post
    Cheers Steve
    Yep been taking 50% out for years now. It's a good number and allows the driver to actually control a slip rather than take away all power
  1. Traction control off
    By Suhail in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2010, 09:29 PM
  2. traction control off
    By jeff keyuk in forum Gen III V8 Specific
    Last Post: February 14th, 2010, 04:11 AM
  3. Traction Control On LBZ?
    By Duramax 6.6L in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 16th, 2009, 09:55 AM
  4. traction control
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: September 29th, 2007, 02:11 AM
  5. 04 vz ss traction control
    By rocket in forum General (Petrol, Gas, Ethanol)
    Last Post: April 5th, 2007, 09:22 AM
