Thread: LLY MAF table limits
    Default LLY MAF table limits
    Ross/Paul, think it might be possible to raise EFILive's B0201 max limit? GM's calibration for the LBZ airbox appears to go over the EFILive imposed limit, as after a fresh flash with the tech2, the tune read out gets the blue bracket indicating EFILive changed the values for the last six cells.
    I must not have that calibration here, can you please post the stock tune that is doing that.
    Here's one. Every 04/05 LLY OS that I've ever read that had the cal for the LBZ airbox has done it.
    Nov 2005
    Ross here is another stock LLY calibration that has the "GM LBZ airbox mod" applied to it. This completely stock...I flashed the ECM with my Tech 2/TIS, and then read the calibration out with EFILive...
    OS 15228758
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Dec 2007
    Ross sorry to bring this back up, I was having issues so i needed to return stock, but because I had already done the lbz air box change and only modded the table in efi, I needed to do the gm update through the tech 2. If I compared the stock gm lbz update to the original lly tune I pulled that had only the maf table changed the difference is night and day. I hardly smoke at all, and it feels much more powerful. I think more was done to the lly tune in the gm lbz update than just 5 values in the maf table, and efi just isnt seeing it.
    Sorry guys, there is just so much going on at the moment this is kind of a low priority.
  1. EFI hard limits B0202
    By sweetdiesel in forum Duramax LB7
    Last Post: January 23rd, 2010, 03:47 PM
  2. Barometric TQ limits (LMM)
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 21st, 2009, 02:15 AM
  3. Paul or Ross, can we change EFI limits on this table?
    By Sparky8370 in forum Duramax LB7
    Last Post: July 19th, 2009, 05:58 PM
  4. r.p.m. limits
    By smokethis in forum Duramax LLY
    Last Post: November 28th, 2008, 08:23 PM
