Results 1 to 2 of 2
Thread: Dyn Jet 248 in Ground Chassis Dynomometer for sale @ Lingenfelters
    Default Dyn Jet 248 in Ground Chassis Dynomometer for sale @ Lingenfelters
    For Sale. Dyno Jet 248 In Ground chassis Dyno
    $9995 usd.
    In service here at Lingenfelter Performance Engineering since Sept.1995
    In good condition and still in use.Possibilities to see in use if time is availible before our new Dyno Jet Chassis Dyno arrives.
    Measures up to 1200 + hp and 200mph
    Contents to Include:
    • Dynamometer Chassis (drums, shaft, bearings, etc.)
    • WinPEP7 Software and Hardware to interface (PC, printer, etc. not included)
    • Ignition Wire Inductive Tachometer Pickup Leads
    • Air Actuated Brake System
    • Remote Software and Brake Control From Driver's seat
    • Automatic Conditions Measurement (absolute pressure, air temp, etc.)
    • Car Retention Barricades ( Are removed in the new remodel pics but can be seen in the older pic below)
    This Dyno is an In ground Dynometer It will require A pit to be constructed to specs found on DynoJet's website.
    The Dyno will be removed and ready to ship per your shipping arangements In mid July
    For questions please call me At Lingenfelter Performance Engineering at 260-725-2552, ext. 1011
    Brent Malone
    [email protected]
    Chassis Dyno / Calibration
    1557 Winchester Rd.
    Decatur, IN 46733
    Dyno is SOLD thanks to all that inquired.
  1. Using Flashscan V2 with LS1 Engine Swapped to Older Chassis
    By Mikey 97Z M6 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 07:55 AM
  2. Replies: 2
    Last Post: May 24th, 2008, 11:34 PM
  3. How did you ground your LC 1?
    By ForcefeedWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2007, 05:52 AM
  4. Looking for PCM P/N for L21 454 (99 P12 RV Chassis)
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: August 20th, 2007, 04:54 PM
  5. Replies: 5
    Last Post: July 28th, 2005, 03:26 PM
