Results 1 to 10 of 17
Thread: e38 4l80 swap 07 silverado cant get speedo to work???
    Apr 2006
    Default e38 4l80 swap 07 silverado cant get speedo to work???
    cannot get speedo on dash to work, the trans will shift so it has to be getting some vss just cant see where, vss shows zero and log shows 0
    ive attached tune from ecm and tcm
    thanks
    Dec 2007
    What trans was in before the 4L80 went in?
    Apr 2006
    4l60
    Need to flash an 80E OS into the TCM or re-pin the harness so you can properly run the 80E with the 60E OS. Have you tried getting the converter to lockup? Id put money on it not locking until you get the OS swapped or repinned.
    Apr 2006
    it has a 80e tune in the t42 and the truck has the speartech harness, no need to pin since its a tcm not a 512k pcm from what i understand.
    Do the TCM pinouts for 4L60E and 4L80E look identical...?
    Check wire continuity between the VSS sensor and the TCM.
    Dec 2007
    So what is this "swap"? A 4L80 into an 07 Silverado or an 07 Silverado powertrain into something else.
    The ECM tune you have runs speedo over CAN from TCM or ABS via BCM normally. Did the tune come from Speartech as well as the harness.
    Difficult to home in on your problem without all the details bud.
    Hi Ian,
    Is the ECM or IPC expecting data from a specific controller id, and did the segment swap cause the controller id to change...?
    Dec 2007
    Hi Ian,
    Yes Joe, very likely if it is what it often proves to be, the speed signal is sourced from the ABS unit and is routed through the BCM to the IPC. HS CAN > LS CAN via BCM. The VSS PID does not show as it is not supplied by the ECM. But hard to know without more details on what the swap components are and where they came from. It may simply be a continuity issue as you point out but I looked at the ECM tune and it is a "BCM speedo source" (my words) tune...but nothing is ever exact with GM and the speedo stuff (as Ross and Paul have often pointed out),
    Cheerz!
    Apr 2006
    it is a 07 silverado, had a 5.3 and 4l60 in it, not swapped into anything
    built 440lsx with nitrous and 4l80 in it now
    harness is from speartech
    they offer no tuning support
    when connected to the tcm with a modis you can see speed and rpm ect, nothing on dash works tho.
    the wiring part seems to be intact. if we get the tcm programed at a dealer with a 4l80e tune for a t42 will it work on the gmlan to communicate with the ecm??
    thanks
  1. 2002 Silverado 4.3 want to swap with V8 (help)
    By robertsschevy in forum Vortec V6/V8 Specific
    Last Post: March 11th, 2010, 03:02 AM
  2. E38 AC management in an engine swap...
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2009, 10:48 PM
  3. pcm swap any 411 will work?
    Last Post: May 25th, 2009, 11:30 PM
  4. E38 6.0ltr Silverado Timing?
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: March 30th, 2009, 03:07 PM
  5. Transmission swap in E38/E67 vehicle.
    By XLR8NSS in forum Gen IV V8 Specific
    Last Post: February 2nd, 2009, 10:04 AM
