Results 1 to 10 of 11
Thread: 04 GTO spark retard problem...
    Sep 2007
    Default 04 GTO spark retard problem...
    this is a 64 impala swapped with 04 GTO LS1 & 4L60E. @ WOT in 2nd gear, timing is retarded down to 0-4 degrees, knocking ALL the power out of it. All ABS & traction control stuff are gone, I believe it may have something to do with that. How do I make it stop retarding? It will not do it in first gear nor Drive, but consistently in 2nd gear. Timing goes from 23 @ WOT immediately down to 0-4 degrees at 3500-3600. I can't find anything that correlates exactly to that. Thanks in advance
    Post your files.
    Are you getting KR...?
    Sep 2007
    here ya go... I can show you the dyno graph also, it will NOT do it in first gear nor 3rd, and it does it on the street as well as the dyno... I can post up the dynograph too, it pulls good to 3500 and then dives.
    thanks
    Sep 2007
    there is little knock retard (2-3) and the engine is stock
    Jun 2007
    Are you using the tcs box deal that came with the 04 gto's I can't remember but I think it has a second weird computer the throttle cable came through. I had the same kind of issue with it my 04 when we gutted the car and got rid of it. Try flashing it to a 2002 camaro. Try this attached file you'll have to retune it or if you want and if I get the time I can copy your files to this OS. I'm not sure when I'll have the time though
    cosmos purple 2004 gto
    408 E85 GT47-91 ,turbo 400,9" currie straight axle,28/10.5w mt et streets
    2005 yellowjacket gto
    417 rwhp and 397 torque
    582 rwhp and 676 torque (150 shot)
    Sep 2007
    can't flash a 512k tune in a 1mb pcm, can ya? I thought of this, just hadn't tried it yet... that is the failure status is gave me...
    Jun 2007
    Or try this tune in it. Just try it and see if it still has the second gear issue. It has all stock spark and ve tables from a 04 gto. I has the theft system disabled.
    Jun 2007
    Oh crap I changed my pcm I forgot about that sry not sure what to do then. Trying to come up with another idea for ya. All the 1mb stuff had Throttle by wire as far as I know hmmmmm let me think awhile.
    Jun 2007
    Okay try this
    Can you hear it knock...?
    Do you not get it in higher gears (3rd, 4th present more load than 2nd)...?
    Is there a possibility that it is a mechanical noise (internal or external)...?
  1. Phantom Spark Retard
    By truethinker in forum Gen III V8 Specific
    Last Post: January 6th, 2010, 06:44 PM
  2. AC spark retard?
    By GMCtrk in forum Gen III V8 Specific
    Last Post: August 28th, 2009, 02:26 PM
  3. Spark Retard
    By eclispe1 in forum Custom Operating Systems
    Last Post: August 23rd, 2007, 09:31 AM
  4. Spark Boost retard table
    By hpcubed in forum Custom Operating Systems
    Last Post: May 24th, 2006, 08:03 AM
  5. nitrous spark retard
    By maxxxboost in forum Tips and tricks
    Last Post: May 11th, 2006, 06:06 AM
