Thread: Locking out gears for sled pulling
    Member SGFastMax's Avatar
    Apr 2009
    Default Locking out gears for sled pulling
    anyone know the propper way to lock out 1st and 2nd gear on a dmax tcm when in 4low for sled pulling?
    Mar 2007
    Why would you pull in 4 low? only thing I see is more chanches of breaking things in front of the tcase from the increased tourqe, But eh I dont pull
    1972 Chevy Blazer, Twin Turbo Duramax 6.6
    69 Maro TT 427 LSX, Wayne due Vett frnt sub,
    Lateral Dynamics 3 link rear, D 60,
    T56, 18X10' 18X12 Boze Forged Speedsters,
    13" wilwood 6 pot fronts 13" wilwood 4 pot rears,
    (all Still under construction)
    Apr 2009
    you could never hold any high rpm in high gear pulling
    Lifetime Member LBZoom's Avatar
    Jun 2008
    As far as I know you have to set the shit speeds and RPM's high enough that those gears won't become active. For example if you set the shift speeds for first and second to 100mph they shouldn't use those gears. Just remember to flash it back before you hit the drag strip otherwise you might kick down into first when you hit 100mph lol. You may also have to lower the shift speeds for the higher gears so they cover the missing ranges of fisrt and second.
    Peace Through Torque
    www.PunisherPerformance.com
    May 2010
    i changed the shift point for first and second to part throttle shift i believe column c not 100% on that at 0 mph then i usually change the tcc to higher rpm
    2004 GMC SIERRA 2500HD ZF6 LLY
    SOUTH BEND DUAL DISC CLUTCH
    FASS FUEL SYSTEMS
    LBZ INTAKE
    Nov 2007
    you could use the scan tool to command that gear.
  1. sled pulling tune
    By browneflatwork in forum Allison 5 & 6 Speed
    Last Post: November 18th, 2009, 03:42 PM
  2. Changing AFR with different gears
    By turbo_bu in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2009, 06:21 AM
  3. sled pulling tune
    By remington_43040 in forum Allison 5 & 6 Speed
    Last Post: April 15th, 2009, 03:20 PM
  4. Different AFR´s in different Gears?
    By Treurentner in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 08:46 AM
  5. Getting different AFR's in different gears ? Why ?
    By J 98ta in forum General (Petrol, Gas, Ethanol)
    Last Post: October 12th, 2005, 04:43 AM
Tags for this Thread
