Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Guide: How to flash the ECM with handheld: V2: BB
    Junior Member Abdulla's Avatar
    Jul 2010
    Post Guide: How to flash the ECM with handheld: V2: BB
    Hello All,
    I prepared a guide (attached) for those who want to flash their ECM/PCM with EFILIVE handheld device (V2) which is being refered to "BBF-(Black Box Flashing)"
    I hope I didn't miss or overlook anything in the guide. And I do appologize for any incorrect english sentences structure or grammer mistakes.
    Thanks to "joecar" for the help and motivation provided to me.
    Regards,
    In tuning you don't understand things, you just get used to them
    - 2008 C6-Z51, LS3, Edelbrock E-force SC, Methanol Injection, ZR1 camshaft, B&B catback-R66
    - 2005 Tahoe-Z71, LM7, Bank's CAI, Eaton E-lockers, Rancho 9000 Shocks
    - 1996 Nissan Patrol, LT1 355 home built corvette engine, H&C, valve train upgrade, cloye's HD chain, Elec water pump, MCleod twin clutch, 3" headers & pipe work
    http://forum.efilive.com/image.php?type=sigpic&userid=10859&dateline=127922  8842
    Abdulla,
    Good job, thanks for the effort... has pictures to go with the text, this is a good feature
    We can get people's review comments and integrate them into the doc.
    I can convert it to .pdf when everyone is happy with it.
    Jul 2010
    Thanks Joecar for your kind words. There is a say here but I really don't know the correct english translation for it, it means "What you give to others, is not anymore yours"....~ "It is more blessed to give than to receive"- Acts 20:35 KJ version
    The file is yours ^_^
    Aug 2008
    Good work Abdulla! Very easy to understand...
    FLASHSCAN V2 & AUTOCAL
    Oct 2006
    Nice work Abdulla.
    The Tremor at AIR
    When we put it in pdf form, it will list your name as the author, that's only fair.
    Here is a preliminary pdf.
    Jul 2008
    Very good job guys!
    Always good to see people get involved...
    Default Additional info
    When configuring Tune Settings for your PCM/ECM/TCM modules, if you have a manual transmission, then do not select a TCM.
    Sep 2003
    When I open this with Adobe the screen goes Black and just the document is displayed, not like a regular pdf document. Is there someting I need to change?
    Thanks.
  1. C6 w/ A6 stuck in 4th after ECM flash only?
    By DVR IMP in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 22nd, 2011, 10:38 AM
  2. 2010 Camaro ECM Flash Counter?
    By RonC in forum E37, E38 & E67 PFI ECM's
    Last Post: September 2nd, 2009, 06:35 AM
  3. flash pinout? 05 ECM serv # 12591279
    By vectorbundle in forum General (Petrol, Gas, Ethanol)
    Last Post: July 1st, 2009, 02:55 AM
  4. can read but cant flash ecm
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2008, 12:37 PM
  5. Holden VX,VY V6 flash ECM's
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: April 21st, 2008, 01:33 AM
Tags for this Thread
