I bought a V1 setup from a guy quite awhile ago, and he had upgraded it to V1 Commercial version. When the cable is plugged in, it accepts the license info fine and works great, but when the cable is disconnected from the computer, it tries to tell me it is in demo mode. The only solution I have found is to change the settings in EFILive to personal, and it will accept the registration info, but does not work when the cable is plugged back in.
Any ideas? Is there an updated registration key that I need that the previous owner did not supply to me? Thanks in advance.
