Results 1 to 10 of 19
Thread: E38 - E67 OS compatibility list
    Exclamation E38 - E67 OS compatibility list
    EDIT: Freshly updated list up to 2011 models, now includes the E37, E38 & E67, see pdf attachment.
    Given the recent problems people have encountered with the 2009 model ECM's and programming with TIS and EFILive to earlier OS's I thought I would create a list of OS numbers that shows what should be ok to upgrade / downgrade to.
    Anything marked as a 2009 ECM do not upgrade an old ECM to this OS or don't downgrade the existing 2009 OS to an earlier OS or it will more than likely result in a corrupted ECM due to a change made to the 2009 ECM's.
    OS Compatibility Guide.pdf
    Dec 2007
    Thanks Ross. Appreciate the time.
    That makes it pretty well cut and dried.
    Do you foresee a time when EFILive will abstract this issue and it will go away?
    Also thanks for the additional T42 capability!!!!
    Cheers and have a good weekend!
    Senior Member doubledip's Avatar
    May 2008
    The List is good but do you have a list of the part numbers of the ECU's that are for each year, surely that would be a better way to know what OS can then go back into the ECU... or are you suggesting that we read the ECU first.. see what column the OS falls under then know we can only put back in another OS from that column?
    you would think there would be specific part numbers for each year/OS other wise if one part number was across both an 08 and 09 OS then you would be able to change OS years
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Dec 2007
    Quote Originally Posted by doubledip View Post
    You would think GM might have had specific part #'s for years, though considering they have been proven to change H/W mid year, and can even specify 2 or more hardware versions in a model year, which then seem to be subject to being superceded........sounds like a good navigation feature for a TomTom .
    May 2008
    they would have specific part numbers for applications... so if the OS changed enough to stop you going backwards then you think it would have a newer part number.. make it easier to identify for spares...
    so there must be some specific part numbers just for these 09 OS's..
    there are 4 that i know of part numbers for the E38's and possibly more , so a list should be able to be made.
    E40's hate 'em
    Quote Originally Posted by gmh308 View Post
    It's a difficult fix and will require a fair amount of time on our part to make it work, in fact I am not 100% it can be done. The problem comes to the fact we can't simply wipe all the data in the ECM and overwrite it with updated data without losing license details etc.
    Much like there is certain LS1 PCM variants that can't be used on certain applications, mail order companies just keep track of what works with what.
    I can only suggest you check the vehicle usage by service number chart shown here -
    http://198.208.187.182/internet/VehiclePartFits.jsp
    I don't have (or know of) every different ECM service number that has come out.
    Dec 2007
    Oki doki thanks.
    Default Yes, THANKS AGAIN!
    Oki doki thanks.
    Thanks again ROSS! I'm using a chart I've been working on with Ian and so far, I've TIS FLASHED 20 new pcms this week for both 08 and 09 cars...and some early ones too with good results.....I'll know more tomorrow when I get to work.
    Thanks again!
    Chuck CoW
    New pdf list posted, now covers all E37, E38 & E67 ECM's up to 2011.
    Hopefully this saves some people some misery.
    Aug 2009
    Yeah !
  1. Compatibility
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2008, 12:53 PM
  2. Viper Compatibility?
    By Donovan in forum Petrol / Gas
    Last Post: August 26th, 2008, 09:21 PM
  3. questions on efi compatibility
    By tippyd in forum General (Diesel)
    Last Post: January 28th, 2008, 09:07 AM
  4. Looking for 100% verification on compatibility.
    By 2kwik4u in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2006, 03:57 AM
  5. Autronic WB w/EFI Live compatibility..
    By Redline Motorsports in forum General
    Last Post: February 20th, 2006, 03:09 PM
