Results 1 to 9 of 9
Thread: Knock PID's on e40 LS2
    Member MadMaxHSV's Avatar
    Oct 2008
    Default Knock PID's on e40 LS2
    Can anyone confirm an assumption of mine, before I sh*t myself that i've actually been seeing a fair bit of knock. (perhaps cue that famous phrase around assumptions)
    I've been logging GM.KNKRET (Knock Retard) and GM.KR (Retard due to knock)
    My assumption based on the fact I've seen some activity on KR and lots on KNKRET is that KNKRET includes burst knock etc, and activity recorded on KR is 'actual' knock from the knock sensors.
    Is that right?
    Although i've noticed another one which is KNK_E40_DMA.....? Not tried logging this one yet.
    Oct 2008
    Ok, a little worrying no-one seems to know what PID shows actual knock.
    Surely this should be somthing monitored during tuning and getting the right one would be quite critical....
    Senior Member MyM8V8's Avatar
    Aug 2008
    A LITTLE worrying???
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Dec 2007
    Quote Originally Posted by MadMaxHSV View Post
    Is that right?
    Try zeroing out burst knock and look at the PIDs again to see whether they are showing the same KR. Usually best to zero/disable burst knock if you a chasing knock questions as burst knock will pull timing on most throttle movements and confuse things.
    GMPX could probably advise what the DMA E40 Knock PID does. Maybe it is actual knock sensor activity.
    Oct 2008
    Ok, i've had a chance to play with a few parameters and I think i've sussed it.
    Firstly I reduced the burst knock values, and the KNKRET value dropped for a similar run.
    I also can get KNKRET to show timing pull just by blipping the throttle when stationary (in one test tune I had 12.5 degrees timing and 14.2 AFR at that moment, don't think this is true knock....)
    I also tested the KNK_E40_DMA PID. And here's my theory. The attached log should bear this out.
    KNKRET shows burst knock retard (plus any real knock recorded on GM.KR) based on change of airflow seen by the MAF.
    KNK_E40_DMA shows burst knock retard based on change of airflow seen based on the APCYL_E40_DMA PID.
    Neither is real knock on its own, although as said KNKRET does include real knock if present, but GM.KR shows this in isolation.
    At the start of the attached log you can see a few throttle blips with a KNKRET peak matching the TPS output, and a KNK_E40_DMA peak matching the APCYL_E40_DMA peak.
    Log_0051.efi
    I have a log somewhere where GM.KR was showing to demo how KNKRET includes it.
    Ok, summary:
    KR = real knock
    KNKRET = real knock and burst knock
    KNK_E40_DMA = burst knock
    have I got that right...?
    [ I deleted my other post above because I was guessing and incorrectly at that ]
    Oct 2008
    Yes I reckon so,
    its possible that KNK_E40_DMA also includes real knock as with KNKRET, but would have to see some to say for sure.
    Oct 2008
    Ok, bit more logging today and saw a little knock. Sh*t way to prove a point but hey
    Final findings are as follows
    GM.KR = Real knock (detected by the knock sensors)
    GM.KNKRET = Real Knock + Burst Knock (based on MAF changes)
    GM.KNK_E40_DMA = Burst Knock (based on APCYL_E40_DMA changes)
    A log which shows this Log_0052finally.efi
    Hope can help someone else remove some uncertainty
    Ok, thanks for info I added a link to this thread from the collected tutorials thread.
  1. LS2 E40 Auto ve help
    By 05lly in forum Gen IV V8 Specific
    Last Post: March 30th, 2009, 06:34 AM
  2. Why can't I log spark knock on 05 E40 VETTES????
    By Chuck CoW in forum Gen IV V8 Specific
    Last Post: October 21st, 2008, 04:32 PM
  3. Cant log ls2 e40
    By Jakes4321 in forum Gen IV V8 Specific
    Last Post: October 29th, 2007, 11:20 AM
  4. LS2 E40 VATS delete?
    By burtoncr in forum Gen IV V8 Specific
    Last Post: October 24th, 2007, 04:10 AM
  5. AutoVE using two LC1'S on a E40 LS2
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: August 30th, 2007, 10:03 PM
