Results 1 to 8 of 8
Thread: GM.E35DSP5_DMA not in my list of PID's
    Aug 2010
    Default GM.E35DSP5_DMA not in my list of PID's
    As the title states I can not find GM.E35DSP5_DMA or GM.E35DSP5V_DMA in the list of PIDs. I shift+F2 to validate the PID's and still nothing. I am running Verison 7.5.6 (build 130). Any help would be greatly appreciated.
    Aug 2010
    Nevermind I got it. Had to reinstall the Scan tune software and boom there they were in the list.
    Sep 2010
    I am having the same issue, i can only view the DSP5 PID's in flashscan V2. I would like to read these DSP5 PID's in the V7.5 scan tool, but they are x'd out, i have had tried many times of validating but still no luck. is it possible you can only read these DSP5 PID in the flashscan V2 but not the V7.5 scan tool? I'm running version 7.5.6 (build 130). LMM application.
    If they have red X thru them, just try to log them anyway.
    Aug 2010
    Make sure you are looking for the PID's listed in my first post. They are the only ones that work for the lmm. At first mine was not there but after I reinstalled the software they showed up. In parenthesis beside the correct PID's will have lbz/lmm. Once you get them double click on the voltage and tune PID and then make sure you push the yellow button down at the bottom to actually see these values change as you turn the knob.
    Sep 2010
    Ok, thanks. i will try uninstallilng and reinstalling the V7.5 software tonight
    Sep 2010
    joecar, i have tried to log them anyways, they still are inactive so no data
    Sep 2010
    Thanks, reinstalling V7.5, the DSP5 LMM PID's showed up. Anyone know where find some EGT's that work for LMM? In PID file 'Duramax_LBZ_Imperial', EGT1;EGT1A;EGT2A, all have incorrect values.
  1. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 10:52 AM
  2. V2 display after selecting a pid list...
    By joecar in forum FlashScan V2 BB Logging
    Last Post: October 30th, 2008, 09:33 AM
  3. 98 4l60e PID list
    By 996pilot in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 18th, 2007, 03:53 PM
  4. need PID list for fast wideband
    By joe'sls1 in forum Gen IV V8 Specific
    Last Post: September 25th, 2007, 07:37 AM
  5. A PID List vs Task Listing?
    By Beer99C5 in forum Tutorials
    Last Post: September 7th, 2006, 08:28 AM
