OK guys. I have all this stuff. Wide band on the pass side, NB O2 stock on the drivers side. Just need a quick walk through on initial baselining. I put these in open air then reset them using the V2? thanks!!!! Also do I tell the V2 this is an LC-1 type sensor on the pass side?
This is from above.................then all you need is the orange null-modem adapter show here (under $3.00): serial-port-cable-that-goes-to-v2
You use the null-modem adapter to connect the LC-1 serial cable to the V2 serial cable.
LC-1 SERIAL OUT --> LC-1 serial cable --> null-modem adapter --> V2 serial cable --> V2
LC-1 SERIAL IN <-- 2.5mm terminator
And then on the V2 LCD, you have to go into Options and configure the serial port for LC-1 wideband. [/I][/SIZE]
