Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: Idle Tips & Tricks
    For 1-D tables (i.e. only one column), you can put any logged pid for the column data.
    If you want to be able to paste-with-labels that map into a tunetool table, then see post #10.
    Senior Member blsnelling's Avatar
    Sep 2010
    For the column, try this:
    goto that table in the tunetool, highlight either the column of interest or the whole table and do rightclick->Copy With Labels...
    then in the scantool, on that map's column tab click Paste Labels.
    I got that part. I thought I had to choose something from the drop down.
    So I'm just collecting the average of each cell, and then pasting that into my table?
    Let me see if I got this right.
    1. Open map properties.
    2. Select the PID for Desired Airflow from the dropdown, set precision to 3. (What's the parameter name? GM.IACDES_B?)
    3. Column gets no selection from the dropdown, type ",Value" for label.
    4. For Row, select SAE.ECT from dropdown, Paste labels from B4307.
    Shawn mentions logging SAE.MAF (g/s) vs ECT at Idle. This table isn't doing that.
    Jul 2008
    Based on your last log, I came up with this value for your 92C entry.
    Let your car sit for at least 12-18 hours. The next morning when you start it up, just log SAE.MAF (g/s) and ECT...ONLY AT IDLE!!!
    Joecar described perfectly how to make the MAP. When you log it, the magic of computers will average your Idle MAF flow. Then just cut and paste those values into B4307. The values/slope should look like an 'inverted' hockey stick.
    The technique is totally separate from RAFIG. You can always log a RAFIG separately or concurrently. The technique is only offered as an alternative for those who may have RAFIG values too low to successfully Idle.
    Sep 2010
    Sorry, but I'm still not clear on this map. What goes in each of the three drop downs for Data, Column, and Row? I understand the values I'm trying to capture, just not clear on creating the map.
    Jul 2008
    Quote Originally Posted by blsnelling View Post
    BLS:
    I used the following EFILive Tutorial when I first started creating MAPS. It really walks you through faster and more clear than I could tell you..plus it is a good way to learn..
    Try it out first..http://download.efilive.com/Tutorials/Interactive/How to Create a Map.htm
    Data = the pid that is to be pasted/multiplied/added into some tunetool table
    Col = Paste Labels button (after doing copy-with-labels from same tunetool table)
    Row = Paste Labels button (the same paste-with-labels info)
    i.e. idea is to make the map look exactly like the tunetool table.
    The map shows the average data when the x-bar button is clicked.
    Sep 2010
    Where I was going wrong, was that I thought it was required to make a choice from the drop downs. I think I've got it ready to go now. Thanks for bearing with me. In the mean time, I did a RAFIG. I'll try again tomorrow morning with this map.
  9. #19
    No worries
  10. #20
    Jan 2007
    Brad:
    Thanks for the feedback and the compliment.
    As to why RAFIG values sometimes appear to be too low for cammed cars, and why MAF Airflow seems to work, is still unresolved in my mind ( I don't know..).
    The intracity of the IAC function and how it interacts with fueling (MAF/VE) is pretty complex. I know 5.7ute and others have been studying actual case studies to understand their function more.
    But I kinda fell upon that observation by happenstance. I knew fueling functions were primarily controlled by the MAF and VE, so I figured that out first. So once LTFT & STFT Trims were +/0, I just used that for my Desired Airflow.
    While I would like to take credit for that 'discovery' a search of the literature shows others have figured that out also.
    Thanks again, and let us know how it goes..
    ..Shawn..
    I just dialed in my desired airflow table this weekend using the MAF, it worked great! Like mentioned i had issues with the RAFIG/RAFPN process, it always came out tooooo low. Thanks for the tip!
  1. Underdrive Pulley & Now A/C Does Not Work at Idle
    By SOMhaveit in forum Gen III V8 Specific
    Last Post: July 6th, 2010, 09:50 AM
  2. idle tuning & airflow
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: October 14th, 2009, 08:47 AM
  3. RTACS tricks and tips................
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2007, 01:27 PM
  4. LS2 Tuning Experiences & Tips
    By oztracktuning in forum Gen IV V8 Specific
    Last Post: November 23rd, 2006, 12:45 PM
