Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Collecting links to scattered material...
  1. #21
    Default Calculated Pids
    Calculated PIDs:
    showthread.php?t=132
    showthread.php?t=130
    showthread.php?t=10
    Non-Linear Calculated PIDs:
    showthread.php?t=4518
    Embedding STATE/TSTATE pids in calc pid:
    showthread.php?t=12081
    showthread.php?p=20356
    Examples:
    showthread.php?15236-A-New-Twist-on-CALC.-VE-Table..Computing-the-Entire-VE-Table.
    My Documents\EFILive\V7.5\User Configuration\calc_pids.txt
Name:	EFILive Calc Pid Operators.png
  2. #22
    Default Bidirectional/DVT
    CASE Relearn:
    10764-crank-relearn
  3. #23
    Default Odd Hardware Related Tuning Issues
  4. #24
  5. #25
  6. #26
  7. #27
  8. #28
    Default Custom Operating System
    COS5:
    Custom-OS-5
    Show-me-your-A0014-s
    Fixing Out Of Range (OOR) Cells:
    help-kr*-problem&p=87052 post #14
    3000-RPM-max-and-setting-codes-03-Z06-with-Magnuson-at-150kPa posts #14, #17
    I-need-help-getting-the-most-out-of-my-car post#2
    More:
    2001-0411-reflash-OS-to-02-12212156-now-wont-start
    COS Upgrade Procedure:
    Upgrade from 12212156 to COS3 or COS5 like this:
    - full flash of COS3/5,
    - cal only flash from 12212156,
    - read back from PCM and save to file,
    - edit file and fix any out-of-range cells (including A0012, A0013),
    - look thru all tables for sane values and fix the insane ones (see
    Important below),
    - cal only flash.
    Important: make sure that all the Axxxx tables and B3647 contain sane values.
    OOR: make sure you get rid of the blue dogear corners.
  9. #29
  10. #30
  1. Replies: 5
    Last Post: January 8th, 2010, 05:53 AM
  2. My V2 is just collecting dust...
    By Teutonic Speedracer in forum FlashScan V2
    Last Post: October 22nd, 2007, 08:23 AM
  3. Local sections?
    By Stangkiller in forum Lounge
    Last Post: September 18th, 2006, 02:47 AM
  4. Links to software suggestions...
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2006, 02:52 AM
  5. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
