Results 1 to 8 of 8
Thread: 06' 6.0L w/ Magnacharger
    Jan 2008
    Default 06' 6.0L w/ Magnacharger
    I have a stock 2006 1500HD with the radix and Magnaflow exhaust. I pulled the superchips file off the truck and have made some changes just to the shiftpoints and added electric fans. I would like to see what else I can do with the tune. With my OS I can't run a COS, so what are you guys doing pick up a little more power out of these trucks? I would soon like to do a smaller pulley and cam but I want to know how to tune first.
    2006 GMC CCSB 1500HD 4X4 - Radix 3.2 pulley, Pacesetter Long Tubes, Magnaflow exhaust
    Jan 2008
    Here is the tune file if this will help
    Dec 2007
    You might want to get a wideband o2 setup and tie it into the efi live so you can see what is going on with air fuel. The tune you have listed currently has a supercharger on it?
    David McLain
    www.etdrag.com
    Jan 2008
    Yes i to have a supercharger on the truck. I do have a wideband O2 on the truck, at idle and cruise it stays around 14.6 at WOT it is around 12.5. The truck also pulls almost 7 degress timing out at WOT. Not sure what to do to correct it, i've read post about it but i don't understand what i need do to correct it.
    Aug 2008
    Post up a data log too...
    FLASHSCAN V2 & AUTOCAL
    Hmmm 12.5:1 for a boosted truck, might want to look at going richer to like 11.2-11.5:1.
    Dec 2007
    Yes post a datalog,
    The a/f is lean because it is only like 4-6 PSI very low most likely.
    David McLain
    www.etdrag.com
    Jan 2008
    Town 001.efiHWY 001.efiWOT 001.efi
    Here are some log files and yes the truck only has about 5-6psi of boost.
  1. Magnacharger
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2005, 03:07 AM
  2. TUN file from a GTO with a MagnaCharger?
    Last Post: February 19th, 2005, 05:07 PM
