Results 11 to 20 of 21
Thread: November 18th 2010 pre-release
    Nov 2007
    The most convenient way to update the script files on your devices is to:
    1. Connect your FlashSCan or AutoCal device to the PC.
    2. Run the EFILive V8 Scan and Tune software.
    3. Select the F5: BBX option.
    4. Click on the [Read] button to read the current setup of the attached device.
    5. Click on the [Program] button which will cause all outdated files to be updated.
    6. It is not necessary to save the BBX Options file after performing the above procedure.
    I'm getting $0194 Write Failure when I try to program the BBX / script file
    Quote Originally Posted by L31Sleeper View Post
    That's usually caused by the CONFIG file system being full.
    Try formatting the config file system (using the drop down option on the Program button) between steps 4 and 5.
    I have made changes that fixes the LS1 logging issues. Please see first post in this thread for the attached download.
    Unfortunately the most recent fixes have not solved the LS1 Scan Tool problem. Further testing today has shown that the V7.5 Scan Tool is still not connecting correctly to the LS1 controller.
    Nov 2007
    That worked, thanx
    Lifetime Member izaks's Avatar
    Aug 2003
    EMAIL sent
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Oct 2010
    I've downloaded the new 7.5 build 136 and v8 build 120 first off how do I download the latest firmware and bootblock? I got firmware 2.07.02 and bootblock 2.07.01 and is there already another build number? Also I tried to open up my previously saved tunes on v8 and it don't recognize them, can I get them to recognize those tunes?
    Oct 2004
    See this knowledgbase article for firmware updates: http://support.efilive.com/kb_articl...7243-SFGL-2949
    Calibrations still need to be modified in the V7 software. V8 should open them and allow pass-thru flashing, but it is not performing calibration modification at this stage.
    Andrew
    EFILive Crew
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    any idea how far away full flash from autocal or V2 will be?
    also remote linking of flashscan to autocal devices?
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
  9. #19
    Oct 2004
    Not sure on the full flash time line sorry. Remote linking however is not something we are implementing. The linking has to be done with the FlashScan V2 and AutoCal device connected (just like it is now).
    Andrew
    EFILive Crew
  10. #20
    Mar 2009
    There was mention before of being able to compare different OS #'s with the new V8 software. How far away will this be?
  1. August 12, 2010 Pre-release
    Last Post: September 29th, 2010, 07:12 AM
  2. Pre release 7.5.1
    Last Post: October 4th, 2007, 08:55 PM
  3. Pre release FYI
    By Techfan in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2006, 10:42 AM
  4. V7.1.9 Pre-release is now available
    Last Post: April 13th, 2005, 02:47 PM
