Results 1 to 10 of 19
Thread: Change number of cylinders? Trying to run LS1 coils
    May 2008
    Default Change number of cylinders? Trying to run LS1 coils
    I am trying to use a LS1 cal file for my LU3 to get some features working like a high resolution crank sensor to use LS1 coil backs.
    Can I just change the number of cylinders in a Camero tune, or can I just change the "Low Resolution Crank" under vehicle platform?
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    I dont think you can do this otherwise lots of guys would run LS1 PCMs on 4 cylinder engines. I could be wrong though!
    Member tunedportcj5's Avatar
    Sep 2006
    Any updates?
    '94 Lexus SC300 LY2 4.8, LS6 cam/springs, E38, LS3 MAF, LS2 intake, 88mm TB, 2bar MAP, T42/4L80e, mpt70
    www.terratraction.com/gallery
    May 2008
    Quote Originally Posted by tunedportcj5 View Post
    Any updates?
    I plan on trying to change the vehicle platform setting to use the high resolution crank sensor. I am not sure how many teeth would be needed on it.
    I found a LS1 reluctor ring, but I will have to wait until I get back from Korea next Aug to do some testing. I have no idea how this ring is arranged (Where 0 DEG timing is), so if that is information someone can provide, it would be a great help.
    48 LB injectors
    T70 turbo.
    Just changing the platform option wont work IIRC, it is for reference and unless the base code is actually in the Camaro tune (doubtful), then it will no do anything.
    I remember this being discussed recently on here, just cant remember where right now.
    Lifetime Member schwoch1's Avatar
    Jan 2009
    Actually, I am using a 0411 PCM on a 4 cylinder engine, a turbocharged 1.3 Suzuki 4 banger in a Chevrolet Sprint........ using coil on plug ignition!!! It works great with zero hiccups!!!
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
    Jan 2009
    Quote Originally Posted by nevinsb View Post
    Can I just change the number of cylinders in a Camaro tune, or can I just change the "Low Resolution Crank" under vehicle platform?
    AFAIK, you cannot use the Camaro cal to run a 6 cylinder engine, the firing events are not spaced the same, IE V8 fires every 45 degrees, and a 6 cylinder fires every 60 degrees, hence the firing events (both coil and injectors) will not fire at the correct time. You can use a V8 cal on any engine that fires every 45, 90,180, or 360 degrees(and a few oddball spacings that most engines will never use). Opens up the possibilities for injecting other engines..... HMMM I got a 5 HP Honda pushmower with carb problems........ '411 swap with coil on plug should work!!! THe only 6 cylinder that uses coil on plug that I am aware of(that uses a friendly computer) is the '08 on up 4.2 I6 in the Trailblazer with the E67 PCM. Hope this helps!!
    Mike
    May 2008
    It's worth looking into. Thanks for the advice.
    48 LB injectors
    T70 turbo.
    Quote Originally Posted by schwoch1 View Post
    Mike
    Yep, thats the only 6cyl with a tuning-friendly ECM is the LL8. 08-09 are the E67 years, 07s should work if you swap the P12 for an E67/T42 combo.
    Care to share with the class how you have your 1.3L turbo 4 running off an 0411? I want to know now!
    May 2010
    Schwoch1, how where you able to get that 4cyl to run from the 0411 ecm? Does it have a reluctor setup similiar to a vortec or LS engine. Did you fabricate some wheels and sensor mounts? Thanks.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  1. Way to change VCM serial number?
    By Fred007 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 19th, 2010, 02:00 PM
  2. LS1 "Mobilgas economy run" - back to the future.
    By emarkay in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2008, 03:39 AM
  3. LS1 to LS2 motor change
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2007, 09:14 AM
  4. Replies: 2
    Last Post: November 29th, 2006, 12:37 PM
  5. 2-3 cylinders down.Any answers?
    By SVR in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2005, 05:12 AM
