Page 9 of 9 FirstFirst ... 789
Results 81 to 83 of 83
Thread: Tutorial: Log Fuel Pressure in EFILive
  1. #81
    Nov 2006
    They are designed for use in commercial refrigeration and air-conditioning applications.
    I've had the AutoMeter sensor installed for a few years now and it still works.
    Honestly I don't look at the PID too much tho.
    LC-1 WBO2
  2. #82
    Dec 2005
    looking for a connector that fits the egr valve connector has any one seen or heard of one,after hooking up my fuel pressure gauge to my egr plug(sliping wires in connector and testing it)I was thinking it would be nice for when I do customer's car's to have a egr connector for quick hook ups (so i am not cutting there wires)any ideas
  3. #83
    Feb 2013
    Just got mine hooked up to my '01 Silverado. I used grey for 5V, purple for ground and brown for 0-5V signal. The colors were different than what the tutorial says.
    Idle pressure is about 52 psi and is within 0.5-1.0 psi of what my mechanical gauge says. Overall I'd say it works pretty well!
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. EFILive AutoVE Tutorial help
    By -=Mod=- in forum Gen III V8 Specific
    Last Post: September 28th, 2009, 03:54 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. EFILive AutoVE Tutorial & 1998
    By eboggs_jkvl in forum General
    Last Post: June 19th, 2006, 03:13 PM
  5. Tutorial for tuning VE using LTFT's using EFILive ??
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2005, 10:55 AM
