Page 15 of 21 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 202
Thread: options request : post your ideas
  1. #141
    Oct 2006
    I would like a way to group calibration tables to a user defined section. Similar to how you can group selected tables to the favourites tab.
    For instance you could name a group "exhaust" & place in this group all the tables you modify when changing an exhaust system. This way you dont need to trawl through the tree to get to the pertinant tables for something where a script is of no real use.
    The Tremor at AIR
  2. #142
    Lifetime Member macca_779's Avatar
    Jan 2007
    Quote Originally Posted by 5.7ute View Post
    Now that's a really good idea right there. I too would really appreciate something like this.
  3. #143
    You mean like multiple favourite lists (with each list being able to be renamed)...?
  4. #144
    Jun 2008
    Is there any plan on implementing a variable TCC enable temp function for GEN3 auto transmissions?
  5. #145
    Oct 2006
    Yes.
    The Tremor at AIR
  6. #146
    Nov 2006
    How about more maps in the maps tab.
    The map bar can easily fit A-Z instead of A-J.
    LC-1 WBO2
  7. #147
    +1 more maps.
  8. #148
    Lifetime Member Biggsy's Avatar
    Jan 2007
    When BB logging (just displaying live data ie. not recording), I would like to be able to have every PID available when scrolling down through the live data without it going slow.
    Have it where the V2 only commands the ECM to stream data of what PID's are currently displayed. So, as you scroll down, the next PID is commanded and displayed and the PID that dissappeared off the top of screen is no longer commanded. This would allow me to have a PID group that has more than 24 channels selected, and no restrictions on data speed. Also, maybe have a button on the V2 that can be pressed that will record current displayed data.
    You could do a similar thing on dashboards in V7/8. Have several dashboards, and, as you flick between them, a new PID list automatically gets streamed from the ECM.
    I hope I explained it correctly (compared to what is in my head)!
    Dave.
  9. #149
    Quote Originally Posted by Biggsy View Post
    Dave,
    +1... I like that idea.
    That is similar to what some scantools like the Genysis/Nemysis do... all pids are being logged, the ones visible on the screen are updated at high priority, the ones not visible on the screen are updated at low priority, and you can dynamically scroll/page up/down thru a long list of pids; it also allows you to move individual pids relatively up/down so that you can group pids together on the screen.
    This allows all pids to be quickly viewed when I have no idea what I'm looking for when troubleshooting.
  10. #150
    Jan 2007
    it also allows you to move individual pids relatively up/down so that you can group pids together on the screen..
    I wanted that too, but couldnt think how to explain it!
    Your reason for wanting this is the same as mine, you dont always know what PID you want.
    Dave.
  1. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 02:12 PM
  2. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 11:03 AM
  3. Any ideas up front
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 02:20 AM
