Results 1 to 8 of 8
Thread: B4001 ifb
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Default B4001 ifb
    I am still chasing my tail with my dieseling. I have a tune that I would like to emulate. I'm stumped trying to get the B4001 from my source tune over to my stock tune base. I am using the stock tune from my car and I am updating the tables manually. My source B4001 IFB is VAC PSI vs IFB (Lbs/Hour) My stock B4001 is Delta MAP PSI vs IFB (Lbs/hour)
    How do I change my stock B4001 to where it matches my source B4001 so when I copy and paste, the tables appear the same and the graph has the same "plots"?
    Elmer
    Hi Elmer,
    absolute rail pressure = gauge rail pressure + BARO
    MANVAC = BARO - MAP
    DeltaMAP = absolute rail pressure - MAP = gauge rail pressure + MANVAC
    gauge rail pressure = 400kPa (58psi)
    DeltaMAP range 400-480kPa maps directly to MANVAC range 0-80kPa...
    i.e.:
    400kPa == 0kPa == WOT
    480kPa == 80kPa == closed throttle decel
    You may have to interpolate in-between cells.
    Apr 2004
    Hm... I didn't know you were fluent in Greek! :p
    Is this before/after what you meant?
    lol, sorry about the Greek...
    0psi VAC corresponds to 58psi DeltaMAP
    (the math is easier when viewed in kPa instead of psi)
    Apr 2004
    So I actually got it right?
    Here's a pic with the silly metric numbers lambda blah...
    Elmer
    Quote Originally Posted by eboggs_jkvl View Post
    Not quite, see attached pic...
    The values in these cells should be equal:
    320kPa <-- -80kPa
    0kPa <-- 0kPa
    480kPa <-- +80kPa
    (and of course, the values in the cells in-between those have to be interpolated).
Name:	B4001 range mapping.jpg
    Apr 2004
    Old people are slow but eventually we get to speed....
    That's it
  1. B4001 question
    By JOHNBOY in forum Custom Operating Systems
    Last Post: April 18th, 2010, 10:41 AM
  2. Help no B4001
    By The Dirty Dutchmen in forum Gen IV V8 Specific
    Last Post: September 20th, 2009, 07:06 PM
  3. Question??? IFR B4001
    By picnic_george in forum General (Petrol, Gas, Ethanol)
    Last Post: May 29th, 2007, 04:50 PM
  4. B4001 IFR settings
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: March 7th, 2007, 04:08 AM
  5. B4001 and boost?
    By DrX in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 25th, 2006, 12:08 PM
