Originally Posted by
ringram
Ok, update from me. I decided to epoxy up the hole and retry perhaps with a smaller hole.
BUT after speaking to Jessie from Waitforme at PRI did some messing with B1650 Max ETC area and what do you know. All seems well now.
Way, way better on cold starts than before and NO HOLE! I told it the area was smaller. Im guessing all the tables we cant see and corrections etc now think the throttle is small so it has to move the blade a larger amount.
I cant remember if Jessie said to make the value larger or smaller, but figured Id play around anyway.
So before anyone drills anything Id try this table first.
I can now drive at idle in 6th gear at 32mph on the flat, no jerking or lurching. Mind you cam is only 227/243-113
