![Quote](images/misc/quote_icon.png)
Originally Posted by
WeathermanShawn
Paul, my mechanical skills are not as great as some.
If you have new O2 sensors and can connect them, then just do that. I think I just bought a set of rear sensors for the additional length of the sensor wire. I guess an O2 is an O2. If you can hook it up, try it out.
As far as the CALC.VE Table values..Try this first. Using the Scan Tool..Calibrations..Long Term Fuel Cells..get those values to re-set to zero.
The main thing is to get your LTFTBENS to near 1.00. Once we get good values and your O2's are switching properly we can evaluate the VE Table Values. On a MAF-Enabled vehicle, the MAF will drive a significant portion of the airflow and fueling. Its hard to say how your VE Table will ultimately look. Most follow what a Torque curve on a dyno would look like.
We need your MAF and O2's first..
