I am playing with an 07 escalade e38 conversion os 12614088 cal 12614085 in a 69 blazer. I have the system up and running, did the vats mod, the engine fires right up runs and works well except the cooling fans, they run all the time. I can command them off with bi directional controls, they stay off untill I exit out of the controls, the pcm is commading the fans on high. I have this wired factor with the series parralell fan wiring. When the engine first starts the fans are off, about one second later the fans go on low, one second later the fans go high and never shut of until the engine is shut off. I have tried tried doing a full reflash again, I have tried changing he coolant fan settings, I have tried applying the cooling fan patch, changing the 192 deg setting (g0901)to 0 nothing seems to correct the problem. I did notice one other odd thing, when I am in the scanner mode and start the engine, the scanner looses comunication unless there is a 120 ohm terminating resistor in line. My snap on scanner works fine either way. There is no codes. ward 07 escalade engine 1-15-11_0005.tun Anyone have any ideas?
