Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: E-ROD Tuning Support
    Default E-ROD Tuning Support
    Hi All,
    The next beta update (probably due in a day or two) will have tuning support for the new GMPP E-ROD ECM. This is just like the older GMPP ECM's in that it's an E67 with some slightly modified code from GM production cars.
    We have completed the mapping for the LS3 tune on this, if anyone else comes across one of these not running an LS3 can they please read the stock tune and Email it in. It's probably going to be the same OS with a different part number and therefore show as unsupported.
    Someone has also put a little text marker in the ECM tune 'HOT RODDING A REVOLUTION IN LS3 E-ROD GMPP 19244810'
    Thanks,
    So would that someone be you, or the guys at GMPP?
    Not us, someone at GMPP.
    Back in the mid 90's Holden/HSV release a calibration that contained the text "aftermarket tunes are s**t", yep, every HSV getting around has that in it.
    Aug 2006
    That's funny!
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
    Nov 2007
    If i remeber rightly there was also a tribute to one of their calibrators lol
    Yes, you are right, that was in another.
    I'm sure on some dusty and scratched CD I have a bunch of the old Holden Memcal files, it would be funny to find them again.
    Dec 2007
    once I found some code that said DEAD in hex.. sorry I couldn't resist.
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    Motorola used to put 0xDEADBEEF in not yet allocated memory.
    swingtan
    Guest
    Can I get some clarification here?
    Is this a new ECM / Calibration for all new HSV's. If so, that would be pretty typical. 5 years ago I bought a new VZ SS, the first of the E38 ECM's here in Aus and a bit over a year latter started getting into tuning at the bleeding edge back then. Now my lease is up and I'm looking at possibly upgrading to a Tourer, am I going to again be at the bleeding edge? Ahh... the joys of tuning
    Simon
    Oct 2004
    Nah, the E-ROD is a GMPP crate motor for hot rod projects. Any HSV you get will have a "normal" factory OS.
    Andrew
    EFILive Crew
  1. Tuning support for Grand Prix GTP?
    By cumminsDK in forum General (Petrol, Gas, Ethanol)
    Last Post: January 16th, 2014, 05:25 PM
  2. Hot Rod Magazine...
    By joecar in forum Lounge
    Last Post: June 21st, 2010, 04:00 PM
  3. EFI Live tuning support in Phoenix AZ?
    By Hagancue in forum Gen III V8 Specific
    Last Post: August 29th, 2008, 10:24 AM
  4. Can you help implement 98 Tuning support?
    Last Post: February 22nd, 2005, 10:44 PM
