Results 11 to 20 of 29
Thread: E-ROD Tuning Support
    Dec 2006
    This is too funny
    8.7 @ 84 (1/8 mile) bolt-ons
    Motorola used to put 0xDEADBEEF in not yet allocated memory.
    In all the PowerPC based ECM's Bosch still do this.
    swingtan
    Guest
    RE: HSV.... Excellent.
    RE: Hidden code, there is also the one where a certain coder implies that any one reading the source looks like they have dressed up in a Halloween costume. Probably the best one I've herd of recently was when the writers of a virus said hello to the techs at Kaspersky and McAfee in their code.
    At least I now know people are reverse engineering our custom OS's
    I have a range of them out there for those inquisitive minds, though don't bother looking at the E38 stuff, I must have lost my sense of humour by then.
    swingtan
    Guest
    not actually reverse engineering, just trying to work out how the fueling is mapped out. I hadn't actually opened a .bin file for a couple of years till I checked one today and even then I didn't do a lot with it. I got a laugh out of the comment though...
    Dec 2010
    Hi
    We are very new to this we have the GMPP E67 e rod kit with fly by wire fitted to a stock LS7 crate motor,there are no cats,standard exhaust and a better air filter system,it all seems to run fine but the map is not good with very slight knocking and lean in places,what tune (map) do these have, should it not be plug and play,at the start of the thread it said you were just starting to look at these what does that mean
    Oct 2004
    They are just a new calibration at the end if the day for us. It is just an ECM and operating system variant that GM are shipping with their E-Rod LS3 now.
    Andrew
    EFILive Crew
    Dec 2010
    Is this the same for the LS7 package,should it not work out of the box
  9. #19
    Dec 2010
    what is meant by e rod tuning support is this the set up i have with the E67 and the LS7 engine
  10. #20
    Dec 2007
    Quote Originally Posted by Warren View Post
    You mentioned no cats. The eRod kit comes with cats. If you are running an E67 with GMPP LS7 tune it should run fine stock. LS7 produces its 505HP through cats with regular gas.
  1. Tuning support for Grand Prix GTP?
    By cumminsDK in forum General (Petrol, Gas, Ethanol)
    Last Post: January 16th, 2014, 05:25 PM
  2. Hot Rod Magazine...
    By joecar in forum Lounge
    Last Post: June 21st, 2010, 04:00 PM
  3. EFI Live tuning support in Phoenix AZ?
    By Hagancue in forum Gen III V8 Specific
    Last Post: August 29th, 2008, 10:24 AM
  4. Can you help implement 98 Tuning support?
    Last Post: February 22nd, 2005, 10:44 PM
