Page 2 of 75 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
    Feb 2009
    Thanks Joe,
    I should have been more clear.
    I was looking for some clarification on this.
    "Stoichiometric AFR (see B3601)"
    I didn't know if this value should be changed in the calc pid to reflect what's in your tune.
    Brad
    Oct 2010
    You can change that. The afr he has is E10 but for gas just change it to 14.63 and you have to go into your tune and make sure your stoich is set to same thing also.
    Feb 2009
    That's what I thought.
    Brad
    Yes, do everything in EQR.
    Set B3601 to the stoichiometric AFR of the fuel you're using (14.63 gas, 14.12 E10, 9.7 E85...)
    There are gasoline/alcohol content measuring kits cheaply available, they come with a stoich AFR chart.
    Last edited by joecar; January 28th, 2011 at 04:43 AM. Reason: removed reference to CALC.STOICH
    Feb 2009
    Thanks guys.
    I'm still learning on the calc pids but that seemed like what you meant.
    Brad
    Jul 2008
    Brad, though the first two PIDS are good ones to have, technically you only need the following to make the formula work (see attachment). This is part of the R&D still being done, but I appreciate the volunteers who are willing to do it.
    As long as you utilize EQ and pick the GM.EQIVRATIO PID in lieu of Commanded AFR, its as easy as it gets.
    Feb 2009
    Shawn,
    I have used EQR since I started using the software.
    That was kinda what sparked the question.
    Thanks for all your help around here.
    You too Joe.
    Brad
    99 Firebird Formula, M6, LS6 intake, headers, catback, lid, BRE cam.
    EFI V2, V7.5.5 (Build 149)
    V8.1.2 (Build 142)
    Boot Block 2.07.01 Oct 14, 2010
    Firmware 2.07.05 Jan 29, 2011
    LC-1 with serial cable
    COS 5
    Shawn is correct, CALC.STOICH and CALC.AFR are not needed (they are purely a mental aid for viewing AFR from GM.EQIVRATIO).
    Shawn has simplified his posted calc_pids.txt file above by removing those two pids.
  9. #19
    Even when using EQR, you still need to set B3601 for the fuel you're running on...
    The PCM does its calculations using EQR, but it still uses B3601 to convert EQR to fuelmass [grams] before calculating injector pulsewidth.
  10. #20
    Thanks.
    Paul found a small bug and fixed it.
    I'll be in Jamaica next week (20th wedding anniversary) and I'm hoping to be able to check the internet.
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
