Results 1 to 9 of 9
Thread: BBx Cal Flash?
    Apr 2007
    Default BBx Cal Flash?
    Can you flash/read LMM trucks standalone now?
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    You can definitely read with BBR now. The write bootloaders are included in the latest builds (in the latest pre-release versions). So it "should" work with both V8 pass-thru and V2 BBF. Please let us know if you have issues.
    Andrew
    EFILive Crew
    Apr 2007
    I didn't successfully flash with the latest software, I could only read with BBX. Pass thru VIA V8 software worked fine for both read and flash..
    I did program for the scripts to update, maybe it missed the flash script.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    What error did you get with BBF?
    Andrew
    EFILive Crew
    Apr 2007
    The error that shows your .obj files are not valid? Not sure can't remember, but I [Programmed] via V8 to my V2 and then the read worked, but never the flash.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    I've asked Paul or Ross to try BBF on an LMM (I don't have one handy ATM). I'll let you know when I get a response.
    Andrew
    EFILive Crew
    Apr 2007
    It could very well be a user Error!
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2004
    Unlikely. The only effect a user really has on a process like that is pressing the button and there's not much room for error there
    Andrew
    EFILive Crew
    I just read and flashed an LMM using BBR/BBF, it worked perfectly.
    Once thing that may be causing the problem is that we changed the code of the MM from "LMM" to "E35B" which is a more accurate controller designation.
    In the BBx setup screen, you may need to double click each of the entries that refer to the LMM (and/or LBZ,LLY and LB7) controllers and make sure the correct controller type is selected for each of those controllers.
    That will ensure the correct supporting files are transferred to the FlashScan/AutoCal device when you click [Program].
    I also recommend formatting the Config file system (using the drop down selections on the [Program] button prior to programming the support files into FlashScan/AutoCal. That will remove any non-essential or out of date files.
    FYI, these are the controller designation changes:
    LB7 -> E54
    LLY -> E60
    LBZ -> E35A
    LMM -> E35B
    LML -> E86
  1. Little help on full and cal flash on DSP tune.
    By Brian1 in forum General (Diesel)
    Last Post: March 15th, 2010, 05:41 AM
  2. Pre Full Flash to Full Flash Tune Question
    Last Post: January 13th, 2010, 12:43 PM
  3. Cal or OS
    By L31Sleeper in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 18th, 2009, 10:10 AM
  4. 07 C6 A6 Speedo Cal
    By Mike@Vengeance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 18th, 2008, 03:26 PM
  5. '08 Corvette A6 Cal
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 18th, 2008, 04:46 AM
