I am not able to log RAFIG or RAFPN because I can't select the required LTD and STD airflow, is this because I have a M6? In absense of logging RAF, I used IACDES_B (ETC) v.s. ECT to map a base airflow but when I map DYNAIR v.s. ECT they are about 2 grams/s lower. Which one should I use? It is idling great at 900rpm with IACDES_B map airflow.
I also can't log cracker and follower PID's.
