Hey guys,
Going through a recent log from a 2009 LMM OS 28594 and noticed that when I play the log back the timing in the log doesn't correspond with my tables.... it goes from being too low, to being too high relative to what I'm supposed to be getting at that mm3 and RPM.... is it just a glitch in the logs?
Also, it's showing that my max timing was 18.8* it should have been several degrees more than that.
Another thing is that I'm commanding a max of 125mm3 of fuel and it showed in that same log that I was maxing out at 106.6mm3....another glitch? I've been through the tune several times and can't find any reason why it should be coming up short.
Thanks for any help!
Is it possibly something in the trans? I guess we still can't read 2009 TCM's huh? I tried several times to upload the stock file even and it kept saying bootloader rejected, I have downloaded the most recent updates...
