Hello, I wrote a tune for the Turbo Brake function to use 95% vane postition from 1200rpm->the end of the rpm map while at 0mm3 fuel command on Low,medium,high Altittude maps for Max vane position and Desired Vane position.
I am wondering if I need to do anything on the tables for Low,Medium and High altitude Desired boost?
Thanks !!!
Tuning by ME
