Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Newbie looking for advise with first tune
    Senior Member Dieselman's Avatar
    Apr 2010
    Default Newbie looking for advise with first tune
    Hello all,
    I am new to this tuning game and would just like to run everything past you guys before I make to many changes. My car is a VE Holden Calais with a L98 and A6
    I have started by following Swingtan's tutorial on VVE setup.
    I did some logging to set up the IAT injector flow modifier table. The first log is factory and the second one is a modified tune. The final tune is running a lot flatter but is still a tad rich, Should I keep trying to get it closer to commanded or will it be OK???
    Any help greatly appreciated
    Ben
    IAT run.efi
    IAT after Mod 3.efi
    Calais VVE setup.tun
    swingtan
    Guest
    Running rich is not a big issue, at least not when setting the IAT correction. All you are trying to do is get the WB signal to indicate a constant combustion AFR over a wide range of IAT readings. You are pretty close looking at the second log, though there is a bit of a step at 66' IAT, but over all it's quite good. You can get the correction closer if you want, then go on to work on the VVE its self. This will bring the WB AFR back towards the commanded.
    Simon.
    Apr 2010
    Thanks Simon
    I didn't know if the AFR had to match commanded or just be flat all the way though the temp range.
    The step was when the Hi speed fans cut in
    swingtan
    Guest
    Yeah, I noticed that, as the MAP and air flow changed. But the AFR line before that was on a steady richening up slope, not a lot though.
    Apr 2010
    Is there anyway to adjust between segments ie in increments of 5 degrees instead of 10???
    swingtan
    Guest
    Nope. I just did the settings at each 10 degree increment and the ECM will blend between them.
    Apr 2010
    Ok that is easy
    Thanks Simon
    Apr 2010
    Ok did some logging tonight and I have now replayed the log but can't get the BEN's to come up on the map???
    Am I missing something here or not
    VVE Log 1.efi
    swingtan
    Guest
    The BEN data is there. You want "BEN Factor Bank 1, Serial Wideband, E38 style". Make sure it's selected in the PID list and then you should be able to put it on a chart / map.
    swingtan
    Guest
    I should also add...
    • Try to keep a steady throttle when logging for tuning the VVE.
    • If you need to add / remove throttle, do so in a gentle fashion. No fast movements!
    • Get as much varying data as you can, hold it in first and take it up to 6000 RPM with very little throttle. Hold it in a higher gear and load it up. change up / down gears when cruising to mix up the data a bit.
    • Don't forget to filter the transient states out!
    • Get lots of data and apply, then log lots of data again.
    Simon.
  1. First tune record - help a newbie
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: September 25th, 2010, 02:37 AM
  2. Advise required by newbie
    By SA1 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2007, 12:10 AM
  3. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
  4. Newbie Supercharger tune questions........
    By FreddyG in forum Gen III V8 Specific
    Last Post: June 19th, 2007, 04:11 PM
  5. Newbie with errors loading stock tune
    By vmax in forum Duramax LB7
    Last Post: May 16th, 2007, 12:07 PM
