Results 1 to 10 of 11
Thread: EFiLive and the '07 BCM
    Apr 2008
    Default EFiLive and the '07 BCM
    Hi... I ran into an interesting problem.
    When I got my E38 ECU ,T42 TCM and the BCM together on a bench harness I realized that I was not able to see the BCM on the CAN bus. Are there any tricks to read and modify a BCM with EFI live?
    Harald
    If nobody has done it before, somebody has to do it....
    1997 Tahoe 2dr 4WD
    2002 Alfa Romeo Sportswagon 2.0 JTD
    1982 Deutz Intrac 2004A
    2003 friesian Horse " Henry"
    Oct 2004
    EFILive will not communicate with the BCM controller, only the ECM and TCM.
    Andrew
    EFILive Crew
    Mar 2010
    are there any plans for efilive to start supporting bcm communication
    Oct 2004
    Not at this stage sorry.
    Andrew
    EFILive Crew
    Dec 2004
    would be nice to be able to clear codes (air bag)
    The EFILive V7 scantool can already clear codes on all modules on the bus...
    go Edit->Properties->Advanced and checkmark Check/Clear DTCs for All Modules, click Ok;
    then go Info->Clear DTC's for All Listed Modules.
    Dec 2004
    the omly module that is listed is the pcm not the bcm.thats usng v1 havent tried v2 on the ls1 yet
    Quote Originally Posted by zrx1200 View Post
    EFILive can still broadcast the clear DTCs message over the bus to all modules (so I understand), but it cannot do anything else to them.
    Also note: on 1998-2002 F-car the BCM is not on the serial bus.
    Dec 2004
    2001 commodore
