Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: EFI Connection Tap Signal Interface
    Aug 2006
    I wonder if we could adapt a t43 to an LT1
    There are a few problems with this...
    - The T43 requires CAN communications and the LS1 PCM has no provision for CAN.
    - No one makes a torque converter to mate the 6L80E or 6L90E to an early SBC or LT1.
    - A Gen IV controller (58x) will require a 4x cam signal. The only solution is a 4x reluctor for a Vortec distributor.
    Unfortunately the 4x cam signal solution in the front of the LT1 did not work, so LT1 owners will have to use the Vortec distributor. TPIS makes a MiniRam for the LT1 and it has a distributor hole.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
    Jul 2003
    Ouch... I would have thought it could work, just like the one you designed for me...
    Oh well... The E38 spits out data so fast it's ridiculous... All we need it to be perfect would be a moates chip in there!
    May 2009
    *subscribing*
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    Aug 2006
    Update.
    Here's the prototype enclosure...before anodize and artwork.
    Aug 2006
    Here is the completed module. EFI# 110-00025.
  1. EFI Connection...you're killing me!
    By DURAtotheMAX in forum Conversions / Aftermarket Parts
    Last Post: February 4th, 2010, 03:31 AM
  2. EFI Connection "24x" System and LS1 PCM for Early Small-Block Chevy
    Last Post: June 1st, 2009, 03:53 PM
  3. EFI Connection "24x" System and LS1 PCM for LT1/LT4 Engines
    Last Post: May 26th, 2009, 01:54 PM
  4. EFI Connection 24x Electronic TPI/LT1 Drive-by-Wire Throttle Bodies
    Last Post: May 26th, 2009, 01:52 PM
  5. Upgrade from auto tap to v2?
    By poolshark021 in forum Purchase and Shipping
    Last Post: May 2nd, 2006, 04:05 PM
