Originally Posted by
jorge
Ok guys, I am following the CalcVe tuning tutorial every thing is going well but need some help understanding what is happening with the tune when the logged data is applied.
Is it fair to say?
-In the MAF table - If the logged bens are low say .97 in order to go to the ideal 1.0 Do the values in the tune need to go down in values? Also lower values equal leaner fueling.
Well, .97 BEN is pretty good. But for example..if you had a MAF Frequency of 5000 Hz X .97 = 4850 Hz..so the numbers go down. I am not 100% sure what the premise of your second question is. A BEN of 1.00 equates to stoich fueling. .97 BEN means the PCM has had to subtract 3% from the Injector Flow to get to stoich. Lower Bens generally mean rich, higher BENS mean leaner.
-The MAF table is more important to be spot on than the VE table.
Thats probably an accurate statement for a MAF-enabled vehicle.
- In the VE table when the values go lower makes the LTFT more positive?
If the vehicle was running solely off the VE Table. In a MAF-enabled vehicle, Trims are primarily driven by the MAF. But the lower the VE Table values, the lower the Airflow values.
Just trying to get a better understanding of what is happening in the tune when the log is applied. So set me strait.
Jorge
