Apparently my LC1 issue was the same, something reprogrammed it to a custom AFR. It would read 4-5:1 via serial, I dont have any analog outputs hooked to it. EQ and Lambda were spot on all the time, I just hooked the LC1 <-> PC cable up for the very first time and did a firmware upgrade plus reset stoich to 14.7. Seems fine now.
