Page 23 of 75 FirstFirst ... 1321222324253373 ... LastLast
Results 221 to 230 of 741
Thread: Calc.VET: correcting MAF and calculating VE (in single log)
  1. #221
    Jul 2008
    Thanks DMAX:
    Joecar has a ton of Links on EQ..so I don't want to butcher his work.
    Here is a start on the EQ/Lamda/AFR conversion. A lot of it depends on B3601 in your Tune. I.E. The conversion of EQ is based off stoich..I'm sure Joecar can give you more data. If not I'll get some for you.
    For anyone reading along, this relationship has to be understood:
    AFR = STOICH_AFR * Lambda = STOICH_AFR / EQR
    and, that relationship applies separately in each of commanded and measured contexts;
    when you cross contexts you get a correction BEN factor (if you cross correctly):
    i.e. BEN is all of these:
    BEN = commanded EQR * measured Lambda
    BEN = commanded EQR / measured EQR
    BEN = measured Lambda / commanded Lambda
    BEN = 1 / (measured EQR * commanded Lambda)
    and other combinations using AFR.
    The easiest BEN to obtain is the first one listed above.
    EDIT: Also check out this calc_pid.txt (look at the last 3 AFR Pids). Joecar breaks down EQ into an AFR conversion..
    http://forum.efilive.com/showthread....l=1#post140820
    Last edited by WeathermanShawn; April 13th, 2011 at 09:36 AM. Reason: Additional Information..
  2. #222
    Mar 2009
    Shawn, yea our scantools must be set up different. I thought that I had that set to disable,(i dont have cats) but I just looked and you are right. (lots of stuff to remember when starting over from stock.) I will try and get a log tonite and with it set to disable and see what happens. I will post the latest tune from the log last nite.
    At any rate in that last log there were only two wot events, one ended up with a ton of wheelspin and the other about 3/4 way through with a long 100% tps then a short one was the ones I was referring to.
    Forgot your other question, it is a cable tb. As far as pe coming in early hopefully it is the cat protection parameter. Take a look at the tune and see if you see anything that isnt set right. There are a fair amount of different tables in the 02 os vs. the 98.
  3. #223
    Jul 2008
    Thanks Len..your right lots to remember.
    I am very curious to know what is causing EQ > 1.00 at various times in your drive. I'm assuming it must be an odd emissions control Table..but nowhere does it display in the Tune. I can't duplicate it my logs..must be a CAT PROT issue...
    Well, worst case we can alter the CALC.PE PID to prevent it from contaminating the data..
    Yea, you have some wild WOT..7000 Rpm's and some nice VSS's... Notice you hit the max MAF frequency too!
  4. #224
    Jul 2008
    Also Len, looking at your Tune..
    You do have B3618 set to 1.137 at >6000 Rpms..right?
    See the screen-shot shows an EQ of 1.25 being commanded at that point..
  5. #225
    Mar 2009
    I have b3618 set up in afr so it is at 12.87 from 2k rpm on. I can set it up in eq, but I understand afr better.
  6. #226
    Jul 2008
    Quote Originally Posted by rpmauto View Post
    Your Commanding 11.7 AFR..
    Probably CAT PROT..Let's see what happens next log..
  7. #227
    Mar 2009
    So the cat protection would drop it that much. I will hopefully get a log tonite. The weather is going to get cold :( and possibly snow a bit here the rest of the week. If not we will have to wait till next week.
  8. #228
    Mar 2009
    I got quick log in tonite, I havent had a chance to really look over it yet. I did see quick that the trims are positive at idle, but they are pretty good the rest of the time. (positive during the one wot i looked at quick) selbens are .9 in the upper range, 1.0 for the rest of the maf table. I still get the high spike in the ve table in the 95 kpa row. (not sure how to smooth that one properly yet)
    I did notice last year when I was on the 98 operating system when I would let off after a wot run the air fuel would go to like 120, I assume DFCO. I havent noticed that with this. Could some erronous data come from that??
    Anyway I will look over the log tonite. Let me know what you think. I would like to track down the discrepency in the difference in air fuel.
  9. #229
    Jul 2008
    Len, Disabling the CAT PROT solved the PE Mode issue and got your Commanded EQ/AFR back in line.
    The only issue remaining are some nagging +Trims during WOT. Trims can sometimes be a hassle. We may need a reset through the Scan Tool..I also will look over your MAF Table and make a few suggestions. Believe it or not Idle +Trims are sometime thrown in at WOT (another emissions issue). But, I have a few ideas that should eliminate those.
    I'll post it up overnight. That should solve whatever Trim/PE Mode issues are still there. I think you are 1-2 Logs away from solving your remaining issues..
  10. #230
    Jul 2008
    Len, if you take your original Tune from a few weeks ago..Gettin Goin SSdemon..
    And using that MAF Table B5001 (which was stock)..and highlighting all MAF Freq from 1500 Hz-12,000 Hz..
    Adjust -5% to -7 % All Numbers..
    That will keep the original injector slope, should get rid of +Trims..you may be a little rich on top..but I think the current MAF Curve is just a little bouncy. You are doing everything right, but just humor me.
    Once you do that log, I can evaluate your VET table a little better..
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
