Results 1 to 10 of 18
Thread: Can't BBX full flash (Error $0502, script file not found)
    Jul 2009
    Default Can't BBX full flash (Error $0502, script file not found)
    I've been through all the instructions and formatted my SD card and config files etc.
    I've then reprogrammed the V2 using Scan&Tune.
    I can read the existing tune off my PCM and can "Program Cal" without problems, but can't "Program Full" without getting the aforementioned script error (even trying to program back the tune I've just read)
    Firmware & bootblocks are up to date. What else can I do?
    EFILive Flashscan V2
    2002 LS1
    Firmware: 2.07.09
    Bootblock: 2.07.01
    Which ECM/TCM controllers...?
    In S&T, under F5:BBX, goto the F:3Tune tab and make a row which specifies your ECM/TCM;
    click the Save button;
    click the arrow part of the Program button, and then click Program All.
    Then, using EE, goto the Config Files tab, check that the _W.bix, _R.bix, _W.obj, _R.obj, .pmm files for your controllers are present.
    Post your Options.txt file.
    Jul 2009
    OK, done all that (and not for the first time!)
    I don't have a TCM, I only have an ECM. The engine is a 2002 LS1 from a Pontiac Firebird, mated to a T56 6-speed (it's in a kit car). All the config files are present
    Options.txt file attached
    2002 LS1
    Firmware: 2.07.09
    Bootblock: 2.07.01
    So on your V2 [Config Files] tab, in the lower pane, do you see these files:
    LS1B_R.bix
    LS1B_W.bix
    LS1B_R.obj
    LS1B_W.obj
    LS1B_M.pmm
    I pm'd Tech Support.
    Jul 2009
    yep, all of those, plus gm_p.dtc, ch_p.dtc, ch_u.dtc (and options.txt)
    2002 LS1
    Firmware: 2.07.09
    Bootblock: 2.07.01
    Jul 2009
    Cool, thanks.
    2002 LS1
    Firmware: 2.07.09
    Bootblock: 2.07.01
    Full flashing LS1 controllers isnt supported yet, the controllers that are supported have a [controller name]_F.bix file. Right now its E40, E37, E38, E39, E67, and E78 plus T42 and T43.
    Have to go back to V7.5 and pass through full flash for now.
    Jul 2009
    Ah, that answers that question then - is this something that might come along later? Good job I've just bought a new netbook with a car charger
    2002 LS1
    Firmware: 2.07.09
    Bootblock: 2.07.01
    Erik, I should have seen that you're right, full flash isn't present yet.
  1. Error $0502
    By Webbs in forum AutoCal
    Last Post: December 9th, 2016, 07:31 AM
  2. Error $0502 Script file not found
    By jcow in forum Allison 5 & 6 Speed
    Last Post: April 14th, 2011, 01:53 AM
  3. BBx Cal Flash?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2011, 11:20 AM
  4. Pre Full Flash to Full Flash Tune Question
    Last Post: January 13th, 2010, 12:43 PM
  5. LBZ Full flash update error...
    By 06Dmaxpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 15th, 2008, 08:42 PM
