![Quote](images/misc/quote_icon.png)
Originally Posted by
johnv
Here is a file i've made a few changes for you.
also need some more information to calc your injector flow rate ( yours looks off a bit)
what is your fuel pressure and is it static or rising rate ?
Adding the CAX file so you can lower the minimum transient pulse width may also help with rich decel/idle mixtures
Your high idle and cruise control effect will be comming from your cam, you will need to log your RAFIG and apply your results to your RAFIG table and also check your IAC counts are around 40-60 at idle.
Get you IFR table were it should be , then work on your VE and then Boost VE tables.
I also prefer to have close to NA timing tables, and use the Boost timing table to remove timing when in boost.
you have yours zerrowed out and are pulling timing from the main spark tables reducing timing and therfore power before you enter boost.
