Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: licensing a used roadrunner
  1. #31
    Cool!
    I just picked an RR.
  2. #32
    Oct 2004
    Mate, you're going to love it!
    Andrew
    EFILive Crew
  3. #33
    Nov 2006
    Welcome to the fold.
    LC-1 WBO2
  4. #34
    Jan 2007
    Wow Joe....really? I thought you'd have had one by now.
    No turning back now mate....you'll be kicking yourself and asking "why the hell didn't I do this years ago?"
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  5. #35
    lol, yeah, I kinda knew that
  6. #36
    Jan 2007
    I am looking at buying a used RR PCM, the 1mb one that matches my truck sooo. From reading that i need to get the following:
    FlashScan Serial number (from oiwners V1 or V2???)
    RR Serial number (From the PCM???)
    matching registration key (For EFI Live or RR???)
    BTW, I have a V2 if that makes any difference.
  7. #37
    Quote Originally Posted by BlackGMC View Post
    Answering the questions, Yes on everything (serial/registration numbers/keys from everything).
    After you obtain all that info, forward that info to EFILive.
    RR works with both of V1 and V2.
  8. #38
    I didn't know the 1MB RR worked... before you buy it can you get the seller to demonstrate it working to you.
  9. #39
    Jan 2007
    do you mean it wont work with a 1mb 03+ PCM?
  10. #40
    Craig Moates has discontinued the 1MB RR:
    Quote Originally Posted by http://support.moates.net/roadrunner/
    Previously, there were Roadrunner versions available for LB7, 1024k ECMs and 98 ECMs. These have been discontinued. If you are confident that you can make it work for one of these applications, you can buy a “guts kit” and fit it yourself. (Or pay us to install it) Again, these applications have been officially discontinued – we cannot guarantee that it will work.
  1. Licensing
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: August 5th, 2009, 12:13 PM
  2. Licensing?
    By Mort in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2009, 03:06 AM
  3. Need help licensing my PCM
    By Snakeaterz06 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2009, 07:58 AM
  4. Licensing
    By Biggsy in forum FlashScan V2
    Last Post: February 6th, 2007, 02:14 AM
