Results 1 to 10 of 10
Thread: Strange Spark Retard - Need Help!
    Oct 2009
    Question Strange Spark Retard - Need Help!
    The attached log shows an anomoly that I can't seem to sort out. The issue is with the spark advance starting at frame 62. The timing goes from about 13 degrees to 7 degrees and then back again. This causes the car to buck in the middle of the RPM range. It typically happens in 3rd and 4th gear. I've followed the spark advance modifiers, but can't quite come up with the calculation that results in the final spark advance. Does anyone know the exact formula for the final spark advance on an E38 ECM? This just started happening since it has warmed up here in Houston (~88 degrees) so I'm thinking IAT modifier?
    E38_0072-SPARK.efi
    swingtan
    Guest
    Any chance you have "Spark Smoothing" turned on? {B0301}, try turning that off.
    Oct 2009
    B0301 - Spark Smoothing Enable = No
    Lifetime Member JezzaB's Avatar
    Nov 2006
    If an area of your VE table is very high it can raise the APCYL_DMA G/Cyl (which your spark table is scaled with) up very high and shift the commanded spark to another area of the spark table. Or if the IFR have been played around with to tune it.
    Oct 2009
    Quote Originally Posted by JezzaB View Post
    I haven't touched the IFR since I changed the injectors. Everything was working fine until the outside temperature changed. VE is high because this is a supercharged application, but the problem is occuring outside of boost (top of stock table) at 1.32 g/cyl. How is actual spark advance calculated? Anyone know?
    Oct 2009
    Any other ideas anyone?
    Dec 2007
    You might try re-scaling the g/cyl axis if it is going off the table with the blower?
    Oct 2009
    Quote Originally Posted by gmh308 View Post
    I think I might have resolved this based on scaling the VE too far as a previous user stated, but I'm maxing out at 1.32 g/cyl how do you scale it for the blower? is it {B5155}?
    Dec 2007
    Quote Originally Posted by mirage View Post
    B5101 - Spark Air Flow Axis...
    Oct 2009
    - B5100 and it looks like it worked. Thanks I really appreciate the help!
  1. Maximum Spark Retard
    By keny in forum E37, E38 & E67 PFI ECM's
    Last Post: July 3rd, 2010, 10:16 AM
  2. Phantom Spark Retard
    By truethinker in forum Gen III V8 Specific
    Last Post: January 6th, 2010, 06:44 PM
  3. AC spark retard?
    By GMCtrk in forum Gen III V8 Specific
    Last Post: August 28th, 2009, 02:26 PM
  4. Spark Retard
    By eclispe1 in forum Custom Operating Systems
    Last Post: August 23rd, 2007, 09:31 AM
  5. nitrous spark retard
    By maxxxboost in forum Tips and tricks
    Last Post: May 11th, 2006, 06:06 AM
