Perhaps cut and paste is looking for the matching P/N values which are not there.
Main thing is to use those MAF g/s values. That will probably give you +2 g/s over what you currently have. Seems like every cammed car wants more air then doing it solely via RAFIG. See now your VE, MAF, and Idle air will match...
Also blend the higher ECTS..
